Начать новую тему Ответить на тему  [ Сообщений: 12 ]
Непрочитанное сообщениеДобавлено: 22 янв 2016, 22:00
Вчера привез домой вот такую акустику:
Acoustic Research Teledyne AR91M
Описание многообещающее:
3 way floor type speaker system of the vartical series which inherited the design philosophy of AR-9.
The 30cm corn type Woofer is carried in low-pass.
The unit of a 1.9cm dome shape is carried in the 3.8cm dome shape and the high region in the inside region.
Between the voice coil and the yoke, the magnetic fruid of the shape of colloid which is tinged with the magnetism of NASA development was put in, and the input-proof is improved while aiming at distorted reduction from a central axis as a structure as for which Bure is not.
Furthermore, the acoustic blanket which is a special sound-absorbing material was attached to the surroundings of a unit, and sound quality degradation by reflective sound is prevented.
A network part puts a speaker on an actual listening room in consideration of dissolution of wall dip, or examination is added under the environment of field front opening of 180 degrees, and the design is carried out.
Moreover, a "17AWG sky core coil", a "computer class electrolytic condenser", "input-proof [ unguided quantity ] ceramic resistance", etc. are used for the element.
The acoustic suspension system of AR tradition is adopted as the enclosure.
By this system, air can achieve the duty of a spring by carrying out full sealing of the core, compliance can be enlarged, and it is possible to make low-pass resonance frequency lower.
Moreover, walnut oil finishing is given.
Характеристики красивые:
System: 3 ways, 3 speaker acoustic suspension system, and a floor type
Use unit: For low-pass: 30cm corn type
For inside regions: 3.8cm dome shape
For high regions: 1.9cm dome shape
Frequency response: 27Hz - 30kHz
Low-pass play frequency: 35Hz -3dB
System Q: 0.6
Output sound pressure level: 87dB/W/m
Impedance: 4ohms (a minimum of 3.2ohms)
The continuation maximum input: 125W
The maximum input: 300W
Crossover frequency: 700Hz, 7.5kHz
Level control: Inside region: Three-step switching
High region: Three-step switching
Content volume: 46.8L
Dimensions: Width 356x height 800x depth of 290mm
Weight: 24kg
Состояние низкочастотных динамиков скверное, даже подключать страшно:
Отсюда вопросы к коллегам:
1. Знаком ли кто-нибудь с подобным изделием?
2. Есть ли смысл заниматься восстановлением подвесов?
3. Сколько это будет стоить?
4. Порекомендуйте мастера в Москве.
Непрочитанное сообщениеДобавлено: 22 янв 2016, 22:09
В Москве есть мастер.Восстановит любые динамики. :cool: Обратись за консультацией и помощью к Николаю Umberto .
Непрочитанное сообщениеДобавлено: 22 янв 2016, 22:16
Его благодарили: 78
Делов то, у нас подвесы на такую акустику, максимум две тысячи, конечно стоит.
"всё имеет свою цену"
Непрочитанное сообщениеДобавлено: 23 янв 2016, 14:13
думаю стоит.
Непрочитанное сообщениеДобавлено: 23 янв 2016, 14:45
Состояние НЧ динамиков, Вам похоже не известно, поскольку еще не включали. А то, шо подвесам хана, так это полная фигня. Уж такой вопрос решается без особых заморочек. Ничего там страшного нет. Вперед!!!
Непрочитанное сообщениеДобавлено: 27 фев 2016, 16:26
Его благодарили: 167
Виталий,если вопрос с подвесами не решили,обращайтесь к Петру Зодниеву ,г.Казань. Я Заказывал на наши родные и на Peerless,Sansui S65, . Цены не высокие.Набирайте- Peter 160@List.ru. С уважением,Марат.
Непрочитанное сообщениеДобавлено: 07 мар 2016, 09:33
Всем спасибо, кто отозвался.
Мастера нашел в Москве.
Перед тем как снять НЧ динамики не удержался подключил и послушал немного акустику на лампе и на камне. На лампе звук так себе, видимо малая мощность у однотактника и невысокая чуйка колонок колонок дали такой результат.
На камне - совсем другое дело. Низ очень роскошный, поэтому решение было принято ставить оригинальные подвесы, которые и заказаны на ебае. Ждемс...
Непрочитанное сообщениеДобавлено: 07 мар 2016, 09:57
Какой ебей!!!
У нас на форуме продают любые подвесы.. кроме квадратных.. :(
Непрочитанное сообщениеДобавлено: 07 мар 2016, 10:25
Их нет, они давно сгнили. Продают новоделы, в любом случае. Вспененный полиуретан - крайне недолгоживущий материал и распадается довольно быстро, так или иначе
Непрочитанное сообщениеДобавлено: 07 мар 2016, 11:13
Его благодарили: 377
Какой ебей!!!
Кто ? Где?
П. Зодиев хваленый мне отказал. Размер видите ли не типичный.
Непрочитанное сообщениеДобавлено: 07 мар 2016, 13:00
Его благодарили: 386
Rodstvenik писал(а):
Кто ? Где?
Я у Сергей1971(на этом форуме присутствует) заказывал подвесы,когда ремонтировал НЧ-динамики к своим "3а".
Непрочитанное сообщениеДобавлено: 07 мар 2016, 16:39
Странно,что отказал,в позапрошлом году делал как раз нетипичные,Насколько я понял иногда бывали проблемы с токарем(пуансон и матрица ведь тоже денег стоят).
cron
